Underdog88
I'm running new cams I've just put in last fall. I know you guys will tell me they're all wrong but it is what I have... I was running almost the same cams with 10* less duration prior and they worked well. I have about 10 hrs now on these motors with no reversion issues with them or the last ones. I have the motors back out for the winter.
Here are the specs:
Hydraulic flat tappet
Basic Operating RPM Range 3,000-6,500
Duration at 050 inch Lift 238 int./248 exh.
Advertised Duration 296 int./306 exh.
Valve Lift with Factory Rocker Arm Ratio 0.540 int./0.540 exh.
Lobe Separation (degrees) 114
I don't want to spin much over 5k rpm and have just under 9:1 compression with aluminum heads and small dome pistons -100cc and 118cc chambers. The cams should have 10:1 compression as recomended by mfgr.
Eldelbrock 750s, RPM air gap, 030over 454s w/100cc domes. Alum heads w/118cc chambers, 2.25/1.88 valves. EMI thunder with long stainless tails(see EGT thread for pics)
They ran well and sound awsome at idle but think I'm leaving some on the table.
My best end of the year run was 79.2 and still climbing slowly at 5k rpm before I hit the no wake zone with a very light load(ran outa gas on the next pass trying to hit 80
) 28 stock Bravo props. 30 Velocity w/-2" IMCO lowers.
The question is...
I've advanced the cam timimg 4* to bring the power band down and this should also increase cylinder pressure, if my thinking is right. This should tame the idle which is pretty radical now, create more dynamic compression and bring the power down closer to the RPM range I plan to run.
Is this a good idea? Am I thinking right? Do you forsee any problems with this?
Thanks for your input!
Mark
Here are the specs:
The question is...
Mark
