Hi guys,
I have a leak somewhere. I Installed new bellows and shift boots last winter, I checked and those are not leaking...
I've noticed some water on the the steering arms; How is the steering arm sealed off?
The boat is pretty transom heavy and the water line is close to the bottom of the bravo sticker on the gimbal housing...
Anyone ever run into this/ know how to fix?
Could one other possible place where the trim indicator wires go thru?
On Another note, I had replaced the lower sections of the outdrives last winter as well, and the new ones sent some metal thru the system. I am getting those rebuilt under warranty and am sure the uppers are fine; My question is how to flush the uppers? can I send oil/ compressed air thru the detent ball fitting?
Thanks!
Thanks!
