ATECO ENGINES
Sponsor
Brad Penn "Penn Grade 1" Racing Oils are specially formulated using high quality PENN-GRADE base stocks and select additive technologies to meet the stringent lubricating demands of high-performance, high stressed, street and racing engines. They deliver excellent shock load and high temperature protection against heavily stressed engine parts including bearings, camshafts, rings, and pistons. They reduce internal friction allowing for increased horsepower output while maintaining their strong lubricating film protection even under the most demanding torque and extreme temperature conditions. Brad Penn Oils have a distinct green color and are available in various viscosity grades to meet your needs. The 20W50 Racing Oil is designed to offer higher performance racing engines the cold temperature operational benefits of an SAE 20W engine oil while providing the desired film strength; sealing abilities; bearing, crankshaft, piston ring and valvetrain component anti-wear protection of an SAE 50 weight oil at normal engine operating temperatures.
