Shah Mat
I found a voltage drop at the merc plug yesterday. My volt gauge was reading 1 volt lower than what the reading was at the battery. It's the ground wire to the all the gauges. When I used the tabs, trim, lights, it would drop even more. Watching the dvom and wiggling the plug the meter was jump up and down. Pulled it apart and the pins aren’t corroded, just dirty.
What is a good way to clean them and do I use a die-electric gel.
