2004 Astro AWD - 120,000 miles
about three weeks ago I lost about 3/4 of the HP. At anything more than 1/4 throttle the engine falls flat on it's face and starts to spark knock
It acted like the exhaust plugged up. I tested for plugged catalitic converters - less than 1 PSI at idle and never saw more than 2 PSI when reved up. Changed the cap and rotor. changed the inline fuel filter ( it was plugged compaired to the new one) Just checked the fuel pressure at the port on the back of the motor. It was 53 at idle and went up to 60 at higher RPM's. I plan to change the plugs and wires after the engine cools off. Air filter is clean. I did have it scaned and the only code was for MAF sensor. I have one off of a good running 2000 ASTRO. This was done before changing the fuel filter. ( couldn't get the old fuel filter out untill two days ago with WD 40) The good used MAF did nothing.
This is a work van and I can't do my job without it. If I take it to a dealership they will just change parts untill they find out what is wrong. The new parts that get installed won't get removed even if they don't help.
HELP
Steve
HELP
Steve
