ao 3100
Must be nice to own an AO AND a Skater. :driving: :) The 3100 has been my droolboat since Ed took me out for a run on Grand Lake.
got the 2 best its hard to pick which is the best they both run hard the only weak link on the ao is the bravo drives they do good by running a lot of rpm and less pitch too much load on them doesnt work we run the ao engines 6700 rpm wot
6700 man you must have BIG hp. I think you posted it in the OSO AO forum but I forget, maybe 2000?
Do shaft drives work on the 3100, or would it be better to have Weismanns for big hp?
yeah agitator, i had a 28 skater then went to a 31AO. Its hard to pick one. I like the quickness of the skater, but really like hanging out on the ao better. Im only running 102 in the ao though.
i will post some pics guys it has 510's blown 871 canfield heads imco boxes with shortie lowers 32 hydro 4 blades labbed also has tunnel tab it runs hard
:26:
Charlie, neutral boxes and -2 inch lowers? Looks like prop shaft is about even with the bottom of the boat. Looks like the skegs have been cut down, have they? Any benefit?
Which IMCO extension boxes do you have installed? Neutral or offset?
What is your final X dimension?
LOTO shootout early 90's. Thats Robbie Morgan before he got banned from the lake.
