Amplifier help
drpete3
When i put the boat away last winter everything was working. Now one of my 2 amps isnt powering up. the power lite is comeing on but dimmer than the one thats working. fuses ok. remote wire ok, ground and power wires ok. I think its internal. can anyone suggest what I should do next?
One idea would be to transfer the inputs and outputs from the "dim" one to the working one to see if the problem goes with. That would isolate the amp from the system.
Take a meter and put it on the wires going to the amplifier. Make sure that it is around 12.8v. If it is it might be in the amp itself.
