32' Pachanga Cabin Door
Poolman
I have a 1987 32' Pachanga restoration in progress, however I cannot seem to locate a cabin door. It is made of molded plexiglass and is unique to the boat. Can anyone give me a direction on where I might find one? Boneyard? A dealership that may have one in its attic??
Help......
Wow, now that's gonna be an interesting search!! I almost bought one of those back when we ended up getting the Scorpion.
Do you have the original door as a pattern? Any acrylic aquarium mfg could do it if so. Actually a fairly easy product to work with.
I do not have the door. When I purchased the boat it had been in storage for eight years. It was in rough shape, Anyways it appeared that someone had smashed the door to gain access to the cabin. I only have a small piece of the door.....
The door is acrylic and has an aluminum frame on the top and I'm almost positive that there is one on the bottom as well. I have the frames as the door was broken out...... Do you have an idea? , because this search is not looking very good......
Well, if you have the frames, you can build the door. The way they form acrylic, you make a wooden pattern to the correct shape, lay the piece of acrylic on it, heat it to 300 degrees, and it ends up the same shape as your pattern. Any acrylic aquarium builder in your area will have the oven I believe.
So, maybe use the frame to fill with a pliable plastic, or layers of cardboard. Use that to make your wooden form, then stick it in an oven at 300. It will droop to fit the pattern. Pull it out, let it cool, cut and buff the edges to fit the frame, attach and done. (Probably sounds a lot easier than it will be).
Paul makes it sound like Toll House cookies in a plastic tube:)
Really it wouldn't be that bad to do.
