Ratickle
Kind of late, but just spotted this one on Ebay...
1974 MAGNUM MARINE-by Don Aronow- 25ft Project boat-No power.
Item Location: Commack, New York, United States
Time left: 1h 49m 7s (Aug 10, 201218:33:05 PDT)
Bid history: 1 bid[Refresh bidhistory]
Current bid: US $2,000.00
Magnum Marine was founded by Don Aronow. These boats are lengendary, known for their rough water handling and speed.This boat is SOLID! The hull is over 3/4" thick.There were approximateley 35 of these built.This hull has undergone a complete removal of engine, wiring and hardware,and windshield. It has been sanded both inside and out, in preperation for new paint. The stringers and bulkheads are rock solid.The only soft spot is a small area in the bow (headliner) that has the repair started, needs to be fiberglassed.The transom core has been removed and a new transom professionally installed. This boat can be rigged for outboard or back to the original I/O..A new aluminum fuel tank has been installed, as well as new fuel fill hose and vent hose. The cockpit is deep and very secure,you will not fall over these sides.I have all the original navigation lights, cleats and Magnum steering wheel. Also included is a Very heavy duty float on trailer, dual axle. ** BOAT IS ALSO BEING ADVERTISED LOCALLY - SELLER HAS THE RIGHT TO CLOSE AUCTION AT ANY TIME**
