from what I was told I need to use an imco spacer B/C I have a bravo upper and imco lower???? I dont see why either one wouldn't work? The imco one I have has no #'s or markings....just came in an imco box. mayby someone could chime in and help explain? do you have pics and how long was it used for?
Some Bravo spacers have a larger diameter stud - not the threaded part, the smooth part. I found this out trying to put IMCO lowers on one where we swapped the factory studs to the Bravo studs and no go - had to order the correct studs from IMCO. We were just testing anyway as the spacer also had larger diameter holes in it.
Now looking for 1/2 inch IMCO spacers - a pair please! I have 1/4 inch Bravo ones if anyone is in need....
SFOcean, what are you looking to get for it?
Rob, is yours an imco? I dont want to start a bidding war but I do need one 1" spacer, prefer imco because thats one that I already have.
Thanks guys
