Results 1 to 20 of 25
    Inside the ILMOR V-10!!
    Sponsor / Charter Member ILMORdude's Avatar
    For your viewing pleasure!! I give you a pictoral build of the ILMOR V-10 725.
    Enjoy..........
    Attached Thumbnails Attached Thumbnails V-10Build 001.jpg   V-10Build 005.jpg   V-10Build 002.jpg
    ILMOR High Performance Marine
    And a few more..............
    Attached Thumbnails Attached Thumbnails V-10Build 006.jpg   V-10Build 007.jpg   V-10Build 008.jpg
    Tulsa, OK/GLOC
    Cool. Wanna donate a pair of those to test their longevity in a Cafe' Racer?
    Temple, PA
    Well, THAT ought to put to rest any questions about whether or not these engines have custom crankshafts...
    Cool how the put the crankshaft position wheel in the middle of the crank, where it's quietest.
    Boating Seriously
    More to follow!!! Stay tuned........
    Founding Member Buoy's Avatar
    Apache Jct. AZ
    Very cool!!
    Or how about just one to see what a 24 Pantera will do with one.
    Lookin' good as usual.
    Curious, with the mention of the crankshafts who does the crankshafts and what material?
    Do all the engines get torn down like this or are only the 650s built on the line at Conner?
    Apr 2009
    ok i have got to ask HOW MUCH IS A 650
    Quote Originally Posted by fantastixvoyage View Post
    650's @ Conner. Forged Steel from SMI.
    Shhhhhhhhhhhh!!!
    COOL SHOT!!!
    Line 'em up.......
    Temple, PA
    Quote Originally Posted by ILMORdude View Post
    Line 'em up.......
    Hmmm....
    So maybe the connecting rods are custom as well?
    Boating Seriously
    Registered Uncle Dave's Avatar
    Feb 2009
    West LA California
    The quality of these parts is fantastic.
    I havent seen the old block to compare, but the new piece is a work of art.
    Uncle Dave
    Great shots! Keep 'em coming!
    ________
    So the main bearing caps are 4 bolt, 2 inside and 2 exterior? Never seen that before. Cool stuff.
    ________
    Feb 2009
    West LA California
    Not sure, but I think externally side bolted mains is an expansion control technique as much as a strength thing.
    I would guess the caps are ductile iron.
    Expansion with alum caps in an aluminum (alloy) block would be too much and the engine would lose oil pressure when hot- iron main caps helps maintain oil pressure.
    I wonder how big you can bore it?
    UD
    Feb 2009
    West LA California
    Also note - the lifter galleries are closed.
    UD
    Registered Donskihp's Avatar
    Mar 2010
    VA.
    Wow! That motor is very impressive! How about the pistons? Are they JE
    Temple, PA
    Ilmor makes their own pistons for the Honda Indy Racing League engines (from solid bar stock!!), but I would guess that these are Mahle forged units...
    Boating Seriously
    Few more.........
    Few more............
    Attached Thumbnails Attached Thumbnails V-10Build 017.jpg   V-10Build 018.jpg   V-10Build 019.jpg
