Results 1 to 7 of 7
    hot tub people! - Blue ridge spas error code ps2
    Exclamation
    Did a google search. Just had it fixed and I am getting a ps2 error code. What do I do?
    And this answer IS time sensitive.
    PS2 code means too many guys in the hot tub
    Mark
    Quote Originally Posted by Wobble View Post
    All over da place.
    I also have a Blueridge Spa. I also got mine used. I have updated the spa pack in mine to the new T series. I can't tell you exactly what the PS1 fault means. I can tell you that I have gotten the PS1 fault from dirty filters. I have also gotten it from a power failure.
    The PS2 fault comes from three things according to Blueridge Spas.
    #1 - Is your water level more than 1" above your highest jet?
    #2 - Are your filters dirty? Are the screens below the filters (pressed in screens - clean them with wet-dry vac) dirty or clogged?
    #3 - Do you have a bad pressure switch? -- The switch that they told me to replace is the one located at the heating element that you are talking about.
    After replacing that switch, I have refilled the hot tub and then powered up only to find that I now have the PS1 fault as well and the ozonator does not come on. If this helps you narrow your problem down, please post again. Maybe I can use the info that you come up with to take care of my problem.
    TAKEN FROM:
    http://spaforums.com/Spa-Repair/Refi...rror_2767.html
    wwwActiveThunderBoats.com
    shame on you
    Quote Originally Posted by Wrinkleface View Post
    follower
    good stuff Brian
    Woke up this morning and it had heated up and the error code was gone.
    Just in time for the weekend.
    Lake Nasty
    I read "blue ridge spas" and pictured something made from old Jack Daniels barrels.
