Thread: What's the max
Results 1 to 10 of 10
    What's the max
    Registered Tony M's Avatar
    Crestwood Il
    On a BARVO 1 WITH A 1" SHORTY , HP / TQ and still have longjevitty
    Tallahassee, FL
    how do you drive? if you don't air it out, shot gun it out of the hole, etc. it will take a lot more power.
    If you ream the crap out of it, hammer the throttle, air it out, land at full throttle and put it away wet a mild small block will blow it.
    Std. Bravo or XR?
    In my experience 5-600 for a std. bravo seems to be about max and 700 for an XR. You can go more but longevity will suffer.
    Naturally aspirated vs. supercharged and RPMS also make a difference.
    Naturally aspirated
    Crestwood Il
    Std. Bravo or XR?
    rpm's about 5200 @ W.O.T MAX drive maped @5600
    It's all going to depend on yoru right arm....
    I like that answer Matt
    So true
    We have up-graded alot of drives with Max Marine, shafts, treated gears, full towers, billet alloy top caps, have ran 900+HP with HI torque, what fails is the junk gears that you have to use, because of the way they are made. If you can keep the drive cool that helps alot, I block the water inlet and add a #8an to the left side of the drive and run the water to the top of the drive with a full plate drive shower that floods the upper with out having the water splash off the drive. The lowers hold up pretty well with a 1.250" prop shaft and a larger vertical shaft from Max, or Imco. I have seen the upper gears seperate from the cone clutch area of the gear, like you just twisted it off! Push out the spanner nut from the case, if it's not an alloy deep thread style from either Max or Imco. The upper gear back-lash settings on a good gear set, stay about right at .005 difference on total run-out of .010- .015 backlash others that are bad can be .008 on one side and 180 degrees be .018-.020. I would agree that 650-700 on an XR will hold up with out alot of hammering. Sorry, if that was to long.
    Charter Member Griff's Avatar
    Omaha NE
    Like this???????
    Mine was still going strong with 275hrs and 550hp in a 5500# boat.
    Registered DollaBill's Avatar
    Or left if it's a beak
    It all depends on your throttle skills.
    Check it out
    Crestwood Il
    best shot's of my drive
    Attached Thumbnails Attached Thumbnails boat&truck 015.JPG   boat&truck 011.jpg
