Thread: TRS Flywheel
Results 1 to 15 of 15
    TRS Flywheel
    Looking for a TRS flywheel.
    Anyone have one laying around ?
    I don't have one , but any top mount starter flywheel will work.
    Flywheel
    I have 2 on the shelf.
    Quote Originally Posted by merlin View Post
    Merlin,
    Are the teeth in good shape? Just checking
    How much with shipping to 66043 ?
    Thanks
    SO Tech Expert Mrhorsepower1's Avatar
    Cleveland,Ohio
    I have many Mercruiser Big Block Chevrolet flywheels. You have a block mounted starter on your engines, correct? (216) 398-8500 I will work you a deal. Thanks
    Dean Gellner
    Quote Originally Posted by CausinTrouble View Post
    What's wrong with the one you have????
    A lot of the standard flywheels are cut for the ring gear on either side. If your ring gear is bad just tap it off, buy another one for $30, heat it up and tap it on.
    Also, is your engine stock? If it's not and it's internally balanced you need a neutral balanced flywheel with the counterweights machined off.
    TRS' as far as I know do not have block mount starters. I have TRS flywheels.
    New Jersey
    Correct Tempest but the truth is the flywheels don't usually go bad just the ring gear. You can get that at a Nappa store cheap.
    I got mine at Auto Zone for $15.00
    Quote Originally Posted by Tempest38 View Post
    i'm purty positive this isn't correct... at least on mine it's not..
    Bradenton Fl.
    merc trans had block mount starter B/W have top mount starter
    Hey guys im in the same boat any help?
    -Mike
    Where the summer never ends
    I have 1 in perfect condition,,,take off ..since i went with billet !!!!!
    taking offers !!!!
    TRS with the BW trannie came with a top mount starter as noted above. It is possible to use a block mount starter too. The boat I have has the block mounted starters. At some convenient point I would like to change them back to top mounts.
    Yes, all u have to do is set the gear ring on the back side !!!
