Page 6 of 8 FirstFirst ... 2 3 4 5 6 7 8 LastLast
Results 101 to 120 of 154
    Charter Member SCARAB3DMC's Avatar
    Cleveland ,Ohio
    Quote Originally Posted by Cigboat#1 View Post
    Dave,stop out to the house when your in Vermilion---Buy you guys a beer!!! Do you know how to get here by boat??
    Jim
    sounds like an offer I cannot refuse, shoot me the directions,
    Registered Cigboat#1's Avatar
    Apr 2010
    Vermilion Ohio
    Dave, first canal past Valley Harbor,hard right and then a quick left ,follow canal around to the end.. Be careful very narrow canal.. House is at the very end of the canal --- check the avatar
    Jim
    Did you hear from that guy from Detroit about your boat?
    Cleveland ,Ohio
    Jim
    What guy in Detroit ???? thanks
    Apr 2010
    Vermilion Ohio
    I guess I read your boat was for sale on another site and thought that some guy from Detroit was interested,,, Thought it was the same guy I told to buy a 34 if he was going to run around on Lake Erie... Maybe I was wrong?
    Jim
    Cleveland ,Ohio
    Jim
    yep she is for sale.. but I have not heard from anyone in Detroit, not pushing the sale too hard anyway...
    Jul 2010
    Stony point
    I got a 86 scarab panther with trs drives and 2 502's..... Can't seem to find the right props to get going... Just blows out and over revs the engines ... Anybody have a clue?
    Finally...In the water....
    Registered Hondo Jet's Avatar
    Feb 2010
    Mooresville, NC
    Any update on this nice 26 ????
    Just put it in the water tonight for the first time. Everything checked out OK, transmission, drive, engine maintained 180/190 degrees throughout some serious flogging. Now its time to get busy on rebuilding the seat bottoms and getting the interior back together.
    I used a 454 that I already had. Not sure how much hp its pushing but seriously doubt if its over 350-375. I knew it ran and in the interest of not spending too much right now went ahead and put it in. I'll build something stronger for it over the winter cause I can already see its begging for another couple hundred HP.
    I need a better set of exhaust manifolds immediately if anyone has some laying around.
    Quote Originally Posted by Denny View Post
    You should ask this question in the props forum, you'll get some responses from the prop manufacturers.
    http://www.seriousoffshore.com/forum...splay.php?f=33
    Jul 2010
    Stony point
    Need help have a 86 panther with2 502with trs drives... Can't figure out what props to run that don't over rev?.
    Registered Scarab KV's Avatar
    Quote Originally Posted by Hondo Jet View Post
    Very nice. Keep us updated
    Jul 2010
    Stony point
    Need help ... Have a 86 scarab panther with 2 502's with trs drives..... Can't figure out what props to use to stop the engines from over revving..... Any clue
    Apr 2010
    Vermilion Ohio
    What size props are you running now??
    Registered jhenrie's Avatar
    Oceanport NJ
    Check with geronimo here. He was panther on the other site. Sure he can give you some guidance.
    Registered Out There's Avatar
    Atlanta
    Great to see that Scarab back on the water so quick!
    Looks very good!
    Jul 2010
    Stony point
    Have try soooo many now running 26 4 blades tried 32 4 blades same problem.
    Registered Rookie's Avatar
    Grand Rapids, MI
    What HP are you running, what speed (GPS) and what are the RPM's that is to much? You need to give a little bit more info if you want some answers. I was spinning 25's around 5100RPMs a little over 71mph. If you are over revving 32's are you sure your trannies aren't slipping?? I had that problem, rebuild time. Also with my 25's I had to add cupping to get mine to stop blowing out.
    Lake Oswego OR
    off topic, but - good to see you here, rookie
    Grand Rapids, MI
    Thanks!! Will try to visit more ofter. Hope all is well with you. And sticking with the theme of your Avatar we need some pics.
    Lake Oswego OR
    a more recent picture
    Atlanta
    Finally have a photo to post. That shot was taken at Lake Murray, SC at their Poker Run.
