Twin 525s
Results 101 to 120 of 420
08-13-2010 02:00 PM
cool project.....will the canopy fall within the Lavin guide lines...that if you wanted to race or build a canopy for a race boat it would pass inspection...
2009 Activator/ Powered by ILMOR
#540 Boat Responsibly Racing
Presented by your U.S. Coast Guard
08-13-2010 02:24 PM
I think Rick's plan is to build a 90 mph canopy similar to a bat boat style. Not a Mystic/Skater 200mph canopy.
- 37,503
08-14-2010 09:43 AMJust buy this one and put all four on......
http://miami.craigslist.org/brw/boa/1889992991.htmlGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
08-15-2010 01:27 PM
We have everything cut off, lowered the deck by 6" Now its time for re-construction of the fwd deck. It looks like we are going to do a custom on-off also, set up for 4, Maybe 5,
Dave Peterson
Zero Defect Marine & Performance
443-370-8734
08-27-2010 12:59 PM
Is this ever a good way to start the day when you walk into the shop?
- 37,503
08-27-2010 01:00 PMAt least they're using a funnel......
08-27-2010 01:02 PM
Back to the grind..
Last night I finished up the wood "striping" and the windsheild are.
08-27-2010 01:05 PM
my angles are at 30 degrees for the best possible deflection. I took the design and help from the aussy..
08-27-2010 01:09 PM
The overall size, length and height fit the boat perfect. The front above the windscreen will be much lower and slopped that what I have now, I just ran out of time last night.
08-27-2010 04:55 PM
Thanks!
But after looking at it I may change the angle from 30 to 25 degrees. The fun never stops.. lol and to be honest I have never done anything like this before, Hell I never even worked with fiberglass till I started this project so Its taking longer than expected.
08-27-2010 06:58 PM
Hey guy just curious are you doing this project in Epoxy ? I gotta tell you seeing that you have never done this type of work before the beauty of everything is... if you f**k it up it can always be fixed and overall when all is said and done i think it will be a nice looker . I was just wondering what you are trying to achive with your canopy as far as what type of material you are going to use fabric / core / ext /ext and how strong ( structural ) do you plan on making the canopy ?
08-27-2010 07:53 PM
I'll be placing 1/2 inch balsa-core (sp?) over the mold I'm making. Than I'll glass and shape it into it's final design. Once thats done, I'll pop the balsa-core part off and glass the inside with a couple sheet of 1708 cloth also giving me 4 layers (and on matt layer on the outside) with a Balsa-core center.
Plus I'll have pillars built in with a roll cage.
With the F16 canopy the boat was a pin in the ass for anything other than racing, now I'll have a 4 person race/poker run boat.
- Dec 2008
- Lake of the Ozarks
- 212
08-27-2010 10:53 PMI will have to post a pic of the deal i started on my floor, Great minds think alike, Same windshield angles etc. for my 30' cat project.
09-12-2010 07:18 PM
today I changed the windshield angle from 30 degrees to 25 degrees and than "shrunk wrapped it"
This will keep the inside clean from resin and help keep the balsa-core from sticking to the part.
09-12-2010 07:32 PM
Looks Awesome.
