We got a visit from the Boss he liked the boat.The cutting table had every glass pattern needed to build this Cat.
Results 981 to 1,000 of 1668
04-10-2010 03:54 PM
04-10-2010 09:40 PM
There is in the far corner a large vacuum gauge on the wall the regulator and there is a vacuum drop every 20 feet going around this shop,Through the door is a complete carpenter shop and up the stairs is the glass cutting loft. a couple 13 Meter cats one in the mold and one on the floor.
04-11-2010 12:13 PM
Here we were doing a sport deck for the 43 falcon.It had a hatch between the engines (Yammars) the owner wanted to carry a jet ski.
04-11-2010 01:28 PM
04-11-2010 01:31 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-11-2010 01:35 PM
Here is one I made connected to the vacuum pipe,This was part of our "Quick bag" system.
04-11-2010 01:37 PM
thats kinda what i did on the smaller pump. I just use a bleeder valve and adjust it on the fly to what i want. I didnt know if there was anything available or if i could just bleed off excess on a bigger system.
04-11-2010 01:38 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-11-2010 01:47 PM
43 Falcon? OK now we got something way new here, what is that?
Looks like a V-bottom deck.
04-11-2010 01:54 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-11-2010 02:03 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-11-2010 02:35 PM
Interesting, any chance i can get some sort of a schematic or instructions on making one? I cant picture what you mean with weights. Thanks
Other then fluctuation in pressure what is the down side to choking?Throttles- Cleveland Construction/Traffic Light Racing 377 Talon cat
04-11-2010 02:40 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-11-2010 03:06 PM
gotcha . . . . so you want to maintain a good volume of air going through the pump and regulate the pressure drawing only what you need from the flow.
04-11-2010 03:13 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
04-11-2010 03:16 PMSlippery when wet. PODLESS TUNNEL www.cheetahcat.com ,Repairs, Modifications and Truing Cheap reliable speed.
