Thread: I have a new toy.......
Results 61 to 80 of 376
04-11-2013 11:05 PMP-4077 "The Swamp" S.B.Y.C. and Michigan medboat mothership
04-11-2013 11:59 PM
I like outboards, I have worked on them most of my life. I could make a pretty good argument that a BBC would be less expensive to operate then a big outboard you mentioned. I say embrace the BBC If you want to race an outboard buy an outboard boat. In the mean time enjoy this one for what it is a BBC stern drive. I would suggest you don't pass up any good deals on stuff needed to keep it a stern drive boat.
Just sayin. Its your program and I will be rooting for you.
04-12-2013 04:11 PM
I can help you get things back in order once your engine is dressed. I have gotten sort of familiar with empty space to big block conversions.
You have a great advantage in that you are only doing one and don't have to find two matching of anything. That will help. Because I built identical twins, I am able to offer the following if you'd like any of it:
Oil pan
Balancer (internal or external... your pick)
Flywheel
Coupler (choice of two, I did new ones because of "Mightaswellitis")
I may also have a battery that didn't get used with a little climate controlled shelf life. Probably pretty stout.
I'll look around this weekend and see if anything else jumps out.
- 37,471
04-16-2013 02:33 AMAnd get a list out there of what you need, or email me. I may have some of it sitting around too.
04-16-2013 05:10 AM
I don't know what I will need untill its time to need it and I cant find it. Though I think Im sitting pretty good. got offshore mounts, upgraded guages and controls coming. My tabs have me a bit perplexed though. can't find a pump much less a hose in the bilge, I think they may be electric??? I know I am going to need a new bilge pump for peace of mind and a new battery. I have 3 props so hopefully one of them works good. End of september is when it really starts, completely derigging, doing the bottom, paint, convert to sitdown, new interior etc.... I do need some of those big rocker trim switches...
04-16-2013 06:22 AM
I'd bet on a missing pump before electric.
- 37,471
04-16-2013 09:37 AMAttachment 75729
Those do appear to be electric
http://www.youtube.com/watch?v=BHVSwA6lP4EGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
04-16-2013 10:50 AM
I second that "huh"
- 37,471
04-17-2013 03:50 PMFrom the looks of the rams, they appear to be the Lenco electric tabs. You should be abble to see with how the wire is coming through the transom instead of hydraulic lines.
04-17-2013 05:10 PM
looking for a set of single controls......
04-17-2013 08:22 PM
And Im still waiting to hear what I need to do/change to make the efi work in a boat that was set up for a carb motor.........
04-17-2013 09:35 PM
nothing. It plugs and plays the same
04-17-2013 09:56 PM
SWEET!!!!!!!!!!!!!! Imagonna be motorboatin within 2 weeks!!!!!!!!!
I even went to walmart today and got fancy new black docklines Was gonna get a battery but forgot to take the battery mount to get the right biggness.P-4077 "The Swamp" S.B.Y.C. and Michigan medboat mothership
04-17-2013 10:17 PM
.... and you can never have too much biggness..........
04-17-2013 10:17 PM
.......unless, of course, it won't fit in the box..............
04-17-2013 10:24 PM
The mounts by rex marine and it definitly has some biggness....
- 37,471
04-19-2013 02:38 AMCan you tell if they are electric tabs yet?
04-19-2013 02:46 AM
thats my suspicion, got wires not hoses.
