Man, that sure looks to be strong as heck.......
Results 281 to 300 of 420
- 37,550
02-02-2013 06:18 AMGetting bad advice is unfortunate, taking bad advice is a Serious matter!!
02-05-2013 06:03 PM
Now so my window ledge has a nice clean edge I'm using my wood window templates as molds.
First thing I did was ran a 1/4 x 3/4 piece or weather strip around the wood. This will give me some wiggle room as
it will be needed for finish cloth and body work later on.
Next I wrapped the part in regular wax paper..
Than began to pre-cut my chop that will run around the mold
I simply wet the chop out...
Allowed it time to dry...
Cut off the excess..
02-05-2013 08:41 PM
v. cool
- 37,550
02-07-2013 06:07 AMDamn that ought to be strong! Nice!!!!!
Hell, I may even get in a boat with you again!!!! Just be careful where you mount the GoPro, I want to see the entire video.....Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
02-07-2013 10:46 AM
It's as build like a Magnum Hull! and we did have the race on video, just that the video was shot from under uyour seat when the camera broke free from the mount. lol
The front window frame was started the same as the two side.. I'll use light weight core, filler and some chopped matt to fill the
areas in between and body work them in. This area is nothing more than cosmetic but will add some strength to the side support
pillars in case of a stuff or hit.
- 37,550
02-08-2013 04:55 AMThat boat was one tight fit.......
I'll have to dig up that vid again.....
I'll also have to dig up my pics of this boat in Harrison that one rough day....Getting bad advice is unfortunate, taking bad advice is a Serious matter!!
02-20-2013 12:16 PM
Step 35,745,415.....
I used chop to in-bed the core to the canopy lip.. this core will be used to "build out" the canopy
giving the window a ledge
Once it dried I used a DA to start shaping the balsa. Its important to take your time
and not just grab a 24G disc to finish in a hurry.. I used a 80G to make sure I did not rip any
pieces of balsa off.
This is only a rough shape, I will be using some light weight filler in the gaps and to finish the
shaping.
Everything was than wet out with a generous amount of resin.
02-20-2013 11:34 PM
good stuff
- 37,550
02-21-2013 10:33 PMSo, are you starting to miss the smell of fiberglass when you're not there?????
- 37,550
03-01-2013 04:21 AMThat really is looking well done. Nice......
03-01-2013 12:58 PMPeople we meet in life are either a Blessing or a Lesson
- 37,550
03-06-2013 05:07 AMHow are you doing on the other boat ?
03-08-2013 08:56 PM
Hey Rick, when you get caught up, i have some glass work for you so you dont get bored... I will even buy beer and pizza......
- 37,550
03-09-2013 08:30 PMJust kind of sneak it in where his is at and he will probably finish yours without even noticing......
03-10-2013 01:44 AM
you know, he isnt really that far .........
- 37,550
03-10-2013 10:23 PMHeck, Rick's inhaled so much glass and resin fumes by now he wouldn't have a clue.....
