I'm moving my electric on my engine from the front to back or somewhere.. Where is your electric mounted on your engine? What bracket are you using? Need Ideas. Pics Ect.. Thanks Scott
Printable View
I'm using the Hardin bracket. I like it although it's a pain in the butt to get at the coil if you have an issue (like the retaining bolt falls out and the coil falls off).
You running MSD boxes Scott?
i think my bracket is all from hardin, harness just plugs into the side, worked great.
While this might or might not help Il go ahead and throw the pics out there, maybe it will give you an idea. I made a simple plate to mount all the junk to the head, TB4 module, cannon plug, circut breaker, and slave sol. Its all in one spot and I eliminated a lot of wire in the process. I used aluminum spacers to distance the parts from the heat of the head.
Even though I am still using t4 boxes I made some holders up from some stock angle and sheet metal I had around and bolted it to the oil filter holder that is bolted to the flywheel housing unused holes.
I use a modified version of the Hardin bracket. Sometime I just buy the lower portion and make my own upper plate to suit my needs. For common parts, it works great. It comes with all of the hardware to mount a box, rev limiter and coil. Here are a few pics of one that I have used in the past. Let me know if you need one. I usually keep them.
Eddie
It is approx. $350.00.
